Assemble job is a processor that offers various schemes for assembling a job folder from individual job files.
The keywords for the Assemble job element are:
Assemble job supports outgoing traffic-light connections of the following types:
Data success: carries successfully assembled jobs.
Data error (optional): carries incoming jobs that cannot be assembled into a job after a certain timeout period.
Name |
Scheme |
Determines the scheme used to assemble jobs:
Every N jobs |
Displayed when Shceme is Arbitrary files. A job is completed whenever it contains at least the indicated number of files; a value of 0 means this option is disabled |
Every N minutes |
Displayed when Shceme is Arbitrary files. A job is completed whenever more than the indicated time has expired since the previous assembly was completed; a value of 0 means this option is disabled |
After N minutes |
Displayed when Shceme is Arbitrary files or Custom. A job is completed whenever more than the indicated time has expired since the first job in this assembly arrived; a value of 0 means this option is disabled |
Number index for total |
Displayed when Shceme is Numbers in filename. The one-based index of the digit group determining the total number of files; automatic means the digit group that represents the largest number |
Number index for serial |
Displayed when Shceme is Numbers in filename. The one-based index of the digit group determining the serial number for each file; automatic means the digit group that represents the smallest number |
Match filename |
Displayed when Shceme is Numbers in filename. The filename without the indexed numbers of the files to asemble in job must be the same. |
Filename pattern 1 … Filename pattern 5 |
Displayed when Shceme is Filename patterns. Up to five filename patterns (using the regular wildcards ? and *) that serve to detect matching files; empty patterns are ignored For filenames to match, they must conform to the specified patterns and the text portions matched by the wildcards must be identical |
Private data key |
Displayed when Shceme is Ungrouped job. The first portion of the private data key used to store the ungroup information; specify the same value as in ungroup job |
Number of files |
Displayed when Shceme is Ungrouped job or Custom. The total number of files expected to complete the output job:
Job identifier |
A string value using variables ( or a script expression), evaluated in the context of each arriving job, that identifies the output job in which the arriving job belongs The string is used only for the purpose of determining which jobs belong together; it has no other meaning |
Complete condition |
A job (using Custom scheme) is completed if this condition is true, even if the required number of jobs hasn't arrived. The condition is re-evaluated for each newly arrived job in the context of that job. A value of None means this option is disabled. |
Merge metadata |
If set to no, the metadata for the assembled job is copied from a single (arbitrary) incoming job, and metadata from all other jobs is lost. If set to yes, the metadata for the assembled job is derived from all incoming jobs:
Job folder name |
The filename of the created job folder, or Automatic to construct a default name depending on the scheme (e.g. the reassemble scheme uses the job name stored by the ungroup tool) Question marks in the filename pattern are replaced by a running count; e.g. Job??? will produce Job001, Job002, ... Variables ( and script expressions) are executed in the context of one of the incoming jobs, chosen arbitrarily |
Subfolder levels |
The number of nested subfolder levels in the job folder being assembled The tool uses the hierarchy location path or the ungrouped job private data to determine where the job should be stored, up to the specified nesting level (similar to archive hierarchy) |
Strip unique name |
If set to yes, the unique name prefix is removed before placing the job in the job folder being assembled |
Duplicates |
Determines what happens when "strip unique name" is set to yes and a job arrives with the same name and location as a job already residing in the job folder being assembled:
Orphan timeout (minutes) |
The time delay after which incoming jobs are considered orphaned because they are not part of a completed job Incoming jobs remain in their respective input folder until the last job arrives that completes an output job folder; whenever a new job arrives, the timeout counter is reset for already arrived jobs that are part of the same output job folder Orphaned jobs are moved along the outgoing data error connection, or if there is no such connection, they are moved to the problem jobs folder |
