JavaScript provides a number of convenient built-in constants, variables and functions.
The built-in constants include Infinity, NaN and undefined.
The built-in variables include arguments.
The built-in functions include eval(), isFinite(), isNaN(), parseFloat(), parseInt().
This is the value of any division by zero, that is,
var i = 1/0;
In JavaScript, division by zero does not raise an exception; instead it assigns the Infinity value as the result of the expression. Use isFinite() to test whether a value is finite or not.
Some functions that are supposed to return a numeric result may return NaN instead. Use isNaN() to check for this.
This is the value of a variable that does not have a defined value, that is, has not been assigned to.
var i;
if ( i == undefined ) {
i = 77;
In this example, if execution reaches the if statement and i has not been assigned a value, it will be assigned the value 77.
This is an array of the arguments that were passed to the function. It only exists within the context of a function.
function sum()
total = 0;
for ( i = 0; i < arguments.length; i++ ) {
total += arguments[ i ];
return total;
This function parses and executes the contents of the string, taking the text to be valid JavaScript.
var x = 57;
var y = eval( "40 + x" ); // y == 97
Returns true if the expression's value is a number that is within range; otherwise returns false.
Returns true if the expression's value is not a number; otherwise returns false.
var x = parseFloat( "3.142" );
var y = parseFloat( "haystack" );
var xx = isNaN( x ); // xx == false
var yy = isNaN( y ); // yy == true
Parses the string and returns the floating point number that the string represents or NaN if the parse fails. Leading and trailing whitespace are ignored. If the string contains a number followed by non-numeric characters, the value of the number is returned and the trailing characters ignored.
Parses the string and returns the integer that the string represents in the given base optBase or NaN if the parse fails. If the base is not specified, the base is determined as follows:
base 16 (hexadecimal) if the first non-whitespace characters are "0x" or "0X";
base 8 (octal) if the first non-whitespace character is "0";
base 10 otherwise.
var i = parseInt( "24" ); // i == 24
var h = parseInt( "0xFF" ); // h == 255
var x = parseInt( " 459xyz " ); // x == 459
