These preferences configure error handling and retry behavior for problem processes.
Abort file transfers after (minutes) |
If an FTP or email file transfer takes longer than this time, it is considered crashed or locked-up and it is aborted (0 means never abort) |
Abort processes after (minutes) |
If a process other than a file transfer takes longer than this time, it is considered crashed or locked-up and it is aborted (0 means never abort) |
Retry mail transfers after (minutes) |
Time interval in minutes between retrying a failed email transfer (0 means "do not retry" which is not recommended) |
Retry FTP transfers after (minutes) |
Time interval in minutes between retrying a failed FTP transfer (0 means "do not retry" which is not recommended) |
Retry unreachable folder after (minutes) |
Time interval in minutes between retrying an unreachable folder (0 means "do not retry" which is not recommended) |
Retry failed external processes after (minutes) |
Time interval in minutes between retrying a failed external process (0 means "do not retry" which in this case is the recommended value) |
