These variables are Switch-specific. The third column indicates the scripting API function that returns the variable's dynamic value.
Variable name |
Data type |
Scripting API equivalent |
Job.ByteCount |
Integer |
Job.getByteCount() |
Job.EmailAddress |
Text Indexed |
Job.getEmailAddresses() |
Job.Extension |
Text |
Job.getExtension() |
Job.FileCount |
Integer |
Job.getFileCount() |
Job.Hierarchy |
Text Indexed |
Job.getHierarchyPath() |
Job.IsFile |
Boolean |
Job.isFile() |
Job.IsFolder |
Boolean |
Job.isFolder() |
Job.JobState |
Text |
Job.getJobState() |
Job.Name |
Text |
Job.getName() |
Job.NameProper |
Text |
Job.getNameProper() |
Job.Path |
Text |
Job.getPath() |
Job.Priority |
Integer |
Job.getPriority() |
Job.PrivateData |
Text |
Job.getPrivateData() |
Job.Size |
Text |
Job.UniqueNamePrefix |
Text |
Job.getUniqueNamePrefix() |
Job.UserName |
Text |
Job.getUserName() |
Job.FileCreationDate |
Date |
The creation date/time of the job file or folder as taken from file system File(job.getPath()).created |
Job.EmailBody |
Text |
The email body text in the email info associated with the job Job.getEmailBody() |
Job.NestedName Indent=" " |
Text Indexed |
A list of indented names (including extension) for all files and folders in the job; by default each level indents with 4 spaces; on a particular level names are sorted alphabetically; see example below The Indent argument specifies the string added for each indentation level (default value is 4 spaces) Script that recursively iterates over job contents |
Nested name example:
The variale [Job.NestedName:Prefix="-> ",Indent=". "] might be replaced by the following lines:
-> My job folder -> . First.pdf -> . Second.pdf -> . Subfolder -> . . Readme.txt -> . Third.pdf
The following variables access a job's occurrence trail to provide information on the job's origin and on why the job was sent to the problem jobs folder. Each of the variables access the most recent occurrence of a particular type, as listed in the table.
Variable name |
Data type |
Most recent occurrence of type |
Job.FailElement |
Text |
Failed |
Occurrence.getElement() |
Job.FailFlow |
Text |
Failed |
Occurrence.getFlow() |
Job.FailMessage |
Text |
Failed |
Occurrence.getLocalizedMessage() |
Job.FailModule |
Text |
Failed |
Occurrence.getModule() |
Job.FailTime |
Date |
Failed |
Occurrence.getTimeStamp() |
Job.Origin |
Text |
Produced |
Occurrence.getOrigin() |
