Saving log messages |
Determines the mechanism for saving log messages into Switch's logging database:
Export messages to XML |
When set to "Yes" the messages stored in the execution log are automatically exported to XML files at a time and interval as configured by the user, starting with the day on which the feature was turned on. The timing can be set to a particular time of the day or with a time delay between two exports. You can also specify the number of days after which the logs should be cleared. You can also choose to export all the log messages or only messages about changes. In the menu, when you select "Yes" option for Export messages to XML, the following fields appear which helps you to configure how and when you want to export the log messages:
The name of the exported files include the Switch server name (see internal communication preferences) and the date in the format: "<server-name> logs YYYY-MM-DD.xml". See Exporting log messages for information on the XML schema of the exported files. |
Log debug messages |
When set to "Yes" any debug messages are written to the regular log database (normally they are ignored). Turn on this preference only when so requested by Enfocus Support, or when you are debugging a script that issues debug messages. |
Log to text file |
When set to "Yes" all execution log messages (including debug messages) are written to a comma-separated text file in addition to the regular log database. Turn on this preference only when so requested by Enfocus Support. |
