Monitor confirmation is a processor that monitors incoming receipt confirmations (generated by Unpack job) and matches them against a copy of the packed data (generated by Pack job) waiting in its input folder. When no confirmation is received after a certain amount of time, tool can be setup to retry the communication (that is, send another copy of the packed data).
See Acknowledged job hand-off for an example of how to use this tool.
The keywords for the Monitor confirmation element are:
Monitor confirmation supports outgoing traffic-light connections of the following types to support its various actions:
Action |
Connection type |
Comments |
Confirm |
Success data |
When a matching confirmation is received, the packed data is removed from the input folder and sent along this connection |
Success log |
When a matching confirmation is received, it is sent along this connection |
Retry |
Warning data |
For each retry attempt (as specified by the tool's properties) a copy of the packed data is moved along this connection; the original packed data stays in the input folder |
Reject |
Error data |
After all retries have timed-out, the packed data is removed from the input folder and sent along this connection |
Error log |
When a confirmation is received that does not match any of the waiting packed data files or that is corrupt, it is sent along this connection |
Name |
Retry count |
The number of retry attempts made when no confirmation is received |
Retry delay (minutes) |
The delay (in minutes) between each retry attempt and the timeout after the last one |
