These preferences configure notification of a system administrator in case of execution problems.
Send problem alerts to |
A list of destination email addresses and body text for each alert message; information about the error is appended to the body text |
Problem job arrives |
If set to yes, send an alert when Switch moves a job into a problem jobs folder |
Processing takes more than (minutes) |
Send an alert if a job takes more than the defined time for processing. When set to 0, this option is disabled. |
Mail server is down for more than (hours) |
Send an alert when an email server cannot be accessed for the indicated time (0 means do not send alert) |
FTP site is down for more than (hours) |
Send an alert when an FTP site cannot be accessed for the indicated time (0 means do not send alert) |
Folder is unreachable for more than (minutes) |
Send an alert when a backing folder is unreachable for more than "minutes" |
External process fails |
Send an alert when a process other than folder fails (that is, its process is put in the "problem process" state) |
Execution log was not finalized |
Send an alert when Switch detects upon startup that the execution log was not properly finalized, indicating that Switch server did not orderly terminate (due to a software or hardware failure) |
Alert if free disk space for application data is less than, Mb |
Send an alert when the amount of free disk space for application data is less than the defined amount. |
