Set hierarchy path is a processor that replaces or augments the hierarchy path in the internal job ticket by constructing a fresh path from the segments specified as its properties. There are five segment properties and thus a maximum of five path segments can be specified (an empty value means "unused").
Since the segment properties support variables ( and script expressions), this tool is a great help when building custom archive hierarchies, for example organizing jobs in a folder hierarchy based on today's year, month, and day.
The keywords for the Set hierarchy path element are:
Set hierarchy path allows only a single outgoing connection.
Name |
Action |
Determines how to combine the new segments with the existing hierarchy location path:
Path segment 1 … Path segment 5 |
The new path segments; an empty value means "unused"; a maximum of five path segments can be specified |
Start index |
The one-based index of the first segment to remove (topmost segment is index 1) |
End index |
The one-based end index of the last segment to remove; zero means until the end of the path |
