Ungroup job is a processor that, in combination with assemble job, provides a way to keep track of files that belong together while they are being processed separately.
Ungroup job injects all files from a job folder into the flow as separate jobs. After these files have been processed through the flow (and possibly were renamed), assemble job can reassemble them into a new job folder with a structure similar to the original one, with provisions for injecting additional files and for dealing with incomplete jobs or orphaned files.
The keywords for the Ungroup job element are:
Split a multi-page PDF file in separate pages; process each page separately through one or more applications that can deal only with a single page at a time; recombine the pages in a job folder; merge the pages into a single PDF file.
Receive a job folder that contains a nested structure of related files; disassemble the folder into separate files; sort the files on file type and put them through some different process depending on the file type; re-assemble the files into a job folder with a structure that is identical to the incoming job folder.
Ungroup job allows only a single outgoing connection.
Name |
Private data key |
The first portion of the private data key used to store the information for reassembling the job later on Varying this value here and in assemble job allows:
Ungroup job stores the following information in the internal job ticket for each injected job file, for use by assemble job:
Private data key |
Stored value |
<key>.JobID |
The unique name prefix of the incoming parent job |
<key>.JobName |
The name of the incoming parent job (without prefix) |
<key>.NumFiles |
The total number of files injected in the flow for this parent job |
<key>.FileName |
The name of this file as injected in the flow |
<key>.FilePath |
The relative path of this file within the parent job folder |
