Attaching Email info
When associating email information with a job, Switch combines the new email information with any email information already present. Email addresses are added to the list, and body text is appended to what's there (inserting a line break if needed). In other words, the effect is cumulative and existing email info is never removed.
Mail receive
The mail receive tool adds email information depending in the email message's origin. Specifically:
The "Base map key on" property defines which attribute of the incoming message is used for matching the mapping table key:
In each case, the email information specified for any matching table entries is added to the job's email information.
Example
You are receiving jobs from different customers. In your company each customer service representative (CSR) is responsible for a well-defined set of customers. You want to setup Switch so that the appropriate CSR is copied on emails sent back to customers.
In the "Base map key on" property, select "Sender's email address".
In the "Email info map" dialog, click the "Add" button; in the "Map key" field enter the customer name (as it is used in their email address) and in the consecutive field enter the email address of the CSR associated with this customer.
Make sure that the map key you have entered matches one of the following:
All jobs sent in by this customer will now have the CSR email address added to their job ticket, which can be used when sending notifications.
Other receivers
Switch tools that receive jobs from external sources allow adding email information based on the job's origin.
For example, FTP receive and submit hierarchy add email information depending on the original job's location in the subfolder hierarchy from which it is retrieved. Specifically, each of the subfolder names in the job's nested subfolder path is used as a key in the mapping table. The email information for all matches is combined and associated with the job.
Folder
A folder provides just a single set of email information. If it is non-empty, the email info is attached to each job passing through the folder.
Here are a few examples of how this can be used:
