Provide Switch with the required data to send e-mails and notifications, to use Active Directory settings etc. Furthermore, you may want to change the language of the interface, to set the preferences for error messages etc.
If you are using Remote Designer, you should define who has the right to access the Switch Server remotely.
If you are using SwitchClient, you should define which users are allowed to access Switch through SwitchClient Submit points and/or Checkpoints, and assign these users the appropriate access rights.
Switch Watchdog (Windows only) as a Windows Service
Set up Switch Watchdog as a Windows Service, to allow Switch to continue processing after you have logged off from the computer.
