Compress is a processor that places the incoming file or a job folder into a compressed ZIP archive. All files in a job folder are placed in a single archive. The archive is named as the incoming file or job folder with a ".zip" extension.
The keywords for the Compress element are:
Compress allows only a single outgoing connection.
Name |
Compress |
If set to yes, the files in the ZIP archive are compressed (the default behavior) If set to no, the files are stored in the ZIP archive without compression, dramatically reducing processing time; this can be meaningful when speed is more important than size, or when the files will not compress well anyway (example: JPEG images) – but you still want a single archive containing all files |
Use password |
If set to yes, all created archives are password-protected |
Password |
The password used for protecting archives |
