The following table indicates what you can do in Switch, depending on the activated modules:
Feature |
Switch Core Engine | Config module | Meta data module | Scripting module | Switch Client module |
Switch Server and Designer |
Flow design (flow wizard, canvas, flows pane, elements pane, properties pane, ...) |
Flow execution (feedback on canvas, messages pane, dashboard pane, statistics pane) |
Built-in tools (see Flow elements matrix) |
Configurators for third-party applications |
Hierarchy info and email info (internal metadata) |
Variables and read-only embedded metadata (EXIF, IPTC, XMP) |
Writing and updating external Xpath-based metadata (XMP) |
External metadata (XML, JDF) and writable embedded metadata |
Script expressions and script elements |
Script development environment (SwitchScripter) |
Scripted plug-ins (if licensed by Enfocus) |
Setup for SwitchClient (users pane, Submit point, Checkpoint) |
Connections to SwitchClient |
