Switch Server name
The name of this instance of the Switch Server. This name will be shown to
users of SwitchClient. It is also used in the title bar of the
application and in the file name of exported logs.
Port for Switch Designer
The port used for communication between Switch Server and Switch Designer, in
the range of 1 to 65535.
Port
for SwitchClient
The port used for communication between Switch Server and SwitchClient
instances, in the range of 1 to 65535.
Port for Switch Watchdog - Switch Server
Server and Switch Watchdog, in the range of 1 to 65535.
Port for Watchdog
The port used for communication between Switch Designer and SwitchClient
The following options are only available if you have licensed SwitchClient.
| Allow older clients to connect (less secure) |
To protect Switch against the Heartbleed Bug (a leak in OpenSSL),
as of Switch 12 update1, Switch Server uses new, secure SSL
certificates for the HTTPS communication with Switch Clients,
Enfocus Connectors and Switch Designer.
We recommend upgrading to SwitchClient 12 update 1 or Enfocus
Connect 12 (as soon as it is available). You must recreate the
Connectors in order to use the new certificates.
However, if you want to establish the communication with older
client applications (released before Switch 12 update 1),
you can still use the old certificates, by setting this
preference to Yes. In that case, be aware
that the connections are less secure.
Note: Keep in mind that all connections (to old and new
clients) use the old certificates.
If set to No (default), the Switch Server
uses the new, secure SSL certificates for HTTPS communication
with Switch Clients, Enfocus Connectors and Switch Designer.
| Compress SwitchClient jobs |
If set to Yes
(default), jobs transferred from and to SwitchClient instances
are compressed (resulting in higher processing time and lower
bandwidth consumption).
If set to No, jobs are
not compressed (resulting in lower processing time and higher
bandwidth consumption); this option is meaningful for high-speed
local networks.
| Maximum number of SwitchClients for iPad |
Maximum number of SwitchClients for iPad that are allowed to
connect to Switch at the same time. |
| Enable Push notifications |
Set this to Yes to enable Push
notifications for SwitchClients to your iPad. These notifications
are used to send job and status information from the Switch Server
to SwitchClient for iPad.If Enable Push
notifications is set to
Yes, the following additional fields
appear:
- Send every (hours): Set
the time interval in hours for Push notifications
- Use proxy: Set this to
Yes to enable SOCKS5 proxy to
send Push notifications. The following additional fields
appear:
- Name or IP address of
host: Enter name or IP address of
the proxy server of your local network
- Proxy user name:
Enter the user name that you use to log in to the
proxy server
- Proxy password:
Enter the password that you use to log in to the
proxy server
- Proxy port: Enter
the port number used for communication with the
proxy server
