Job group
These variables are Switch-specific. The third column indicates the scripting API function that returns the variable's dynamic value.
Variable name
Data type
Scripting API equivalent
Job.ByteCount
Integer
Job.getByteCount()
Job.EmailAddress
Text Indexed
Job.getEmailAddresses()
Job.Extension
Text
Job.getExtension()
Job.FileCount
Integer
Job.getFileCount()
Job.Hierarchy
Text Indexed
Job.getHierarchyPath()
Job.IsFile
Boolean
Job.isFile()
Job.IsFolder
Boolean
Job.isFolder()
Job.JobState
Text
Job.getJobState()
Job.Name
Text
Job.getName()
Job.NameProper
Text
Job.getNameProper()
Job.Path
Text
Job.getPath()
Job.Priority
Integer
Job.getPriority()
Job.PrivateData
Text
Job.getPrivateData()
Job.Size
Text
Job.UniqueNamePrefix
Text
Job.getUniqueNamePrefix()
Job.UserEmail
Text
The user's email address associated with the job (as entered in the Users pane). If no user information has been linked to the job, the variable remains empty.
Job.getUserEmail()
Job.UserFullName
Text
The user's full name associated with the job (as entered in the Users pane). If no user information has been linked to the job, the variable remains empty.
Job.getUserFullName()
Job.UserName
Text
Job.getUserName()
Job.FileCreationDate
Date
The creation date/time of the job file or folder as taken from file system
File(job.getPath()).created
Job.EmailBody
Text
The email body text in the email info associated with the job
Job.getEmailBody()
Job.NestedName
Indent=" "
Text Indexed
A list of indented names (including extension) for all files and folders in the job; by default each level indents with 4 spaces; on a particular level names are sorted alphabetically; see example below
The Indent argument specifies the string added for each indentation level (default value is 4 spaces)
Script that recursively iterates over job contents
Nested name example:
The variable [Job.NestedName:Prefix="-> ",Indent=". "] might be replaced by the following lines:
-> My job folder
-> . First.pdf
-> . Second.pdf
-> . Subfolder
-> . . Readme.txt
-> . Third.pdf
The following variables access a job's occurrence trail to provide information on the job's origin and on why the job was sent to the problem jobs folder. Each of the variables access the most recent occurrence of a particular type, as listed in the table.
Variable name
Data type
Most recent occurrence of type
Job.FailElement
Text
Failed
Occurrence.getElement()
Job.FailFlow
Text
Failed
Occurrence.getFlow()
Job.FailMessage
Text
Failed
Occurrence.getLocalizedMessage()
Job.FailModule
Text
Failed
Occurrence.getModule()
Job.FailTime
Date
Failed
Occurrence.getTimeStamp()
Job.Origin
Text
Produced
Occurrence.getOrigin()
Job.Origin
Use this variable to get the original location of the job before it was injected or submitted into the flow:
  • For a Submit point, this is the original file path of the job submitted to Switch via SwitchClient.
  • For an FTP receive element, this is the path to the file on FTP server that was used to download the file.
  • For a Mail receive element, this is the ‘From’ address of the email.
  • For a Script element, this is the path that was passed into "createNewJob". Note that the "createNewJob" function can be called with or without a path parameter, so it's up to the script writer to provide the Job.Origin value or to leave it empty.
Note: For other elements, this variable is empty!
