Active Directory Settings are only relevant if you want to use your existing Active Directory user accounts to define access rights for SwitchClient and/or Remote Designer. For more information, refer to Setting up Switch users.
Double-clicking Active Directory information, displays a dialog with the following fields:
| Property | Description |
| Server address | Address of the Active Directory server. Example: SERVER001.enfocus.com |
| Server port | Port number of the Active Directory server. Example: 389 |
| LDAP version | The version of the LDAP protocol used on your Active Directory server. Example: 2 or 3 (default) |
| Base DN | Distinguished name to be used as the search base. Example: Usually, users and user groups are located under the domain name. If users are stored in the folder enfocus.com, the base DN is: DC=enfocus;DC=com. Note: If you don't know the base DN, you can leave it empty. Once you have
executed an AD directory query, it will be filled in automatically.
| User | User name to log on to the Active Directory server. The user name is usually preceded by the domain name. Example: enfocus\user1 |
| Password | Password to log on to the Active Directory server. |
