Log job info
Log job info is a processor that issues a message to the Switch execution log containing the value of the specified metadata field. It is intended mainly for use while testing a flow.
Keywords
The keywords for the Log job info element are:
Connections
Log job info allows only a single outgoing connection.
Properties
Property
Name
Message text
The message to be logged; %1 will be replaced by the argument value; if %1 is not present it is added at the end of the string
Message level
Determines the message level: Info, Warning or Debug
Scheme
Determines the scheme used to specify a metadata value:
  • Direct: use variables or a script expression to calculate a value
  • Location path
  • Key/value pair
Value
The value to be logged
Dataset
The name of the metadata dataset to query; Default means the embedded dataset
Data model
The data model used for querying the dataset (one of XMP, JDF, XML); this must match the data model of the dataset except that XML can be specified to query JDF
Location path
The location path pointing at the value to be logged (for XML this can be an arbitrary XPath expression)
Array location path
The location path pointing at the array containing the key/value pairs
Key name
The name of the key field
Key contents
The value of the key
Value name
The name of the value field
