Opaque pickup
Opaque pickup is a processor that allows associating an arbitrary file with a job as metadata. It supports the following pickup mechanisms:
Keywords
The keywords for the Opaque pickup element are:
Data model
The metadata source can be any file (but not a folder). The dataset data model is Opaque.
Connections
Opaque pickup allows only a single outgoing connection.
Properties
Property
Name
Dataset name
A name for the set of metadata picked up by this tool; see picking up metadata
Pickup mode
The pickup mechanism; one of:
  • Metadata alongside asset
  • Metadata in job folder asset
Additional properties are shown depending on the selected pickup mechanism; see the description of each mechanism for more information.
