Recycle bin is a consumer that deletes incoming jobs either immediately or depending on the jobs size, age etc...
The keywords for the Recycle bin element are:
Recycle bin does not allow outgoing connections
Name |
Path |
The path of the recycle bin's backing folder on disk, or "auto-managed" |
Keep N jobs |
If non-zero, the recycle bin delays deletion of jobs until the total number of jobs in the recycle bin exceeds the given limit; the oldest jobs are then deleted until the number of jobs in the recycle bin is once again under the limit The "Save..." properties of the recycle bin tool are independent; jobs are deleted as soon as they exceed the limit of any of the "Save..." properties |
Keep N MB jobs |
If non-zero, the recycle bin delays deletion of jobs until the total size of all jobs in the recycle bin exceeds the given limit; the oldest jobs are then deleted until the total size of the jobs in the recycle bin is once again under the limit The "Save..." properties of the recycle bin tool are independent; jobs are deleted as soon as they exceed the limit of any of the "Save..." properties |
Keep jobs for N (hours) |
If non-zero, specifies the number of hours that the deletion of jobs by the recycle bin should be delayed; any job that is older than the limit is permanently removed from the recycle bin The "Save..." properties of the recycle bin tool are independent; jobs are deleted as soon as they exceed the limit of any of the "Save..." properties |
Move to system recycle bin |
If set to yes, jobs deleted by the recycle bin tool are not permanently deleted but instead moved to the system recycle bin |
Strip unique name |
If set to yes, the unique name prefix added to the filename by Switch is removed before moving the job to the system recycle bin |
