Uncompress
Uncompress is a processor that extracts files from an archive in one of the following formats:
Any files that are not recognized as an archive are passed through the uncompress tool without change.
Keywords
The keywords for the Uncompress element are:
Filenames and folder structure
The following table describes the resulting file or folder structure and the corresponding naming conventions.
Multiple files from the same archive are always placed in a job folder. If the intention is to inject these files into the flow as separate jobs, a job dismantler should be placed directly after the uncompress flow element.
Archive contents
Uncompress result
Single file
The file (named as specified in the archive).
Multiple files or folders with a common root folder
A job folder (named as the nearest common root folder) containing all files and folders (named as specified in the archive).
Multiple files or folders without a common root folder
A job folder (named as the archive after stripping the extension) containing all files and folders (named as specified in the archive).
Connections
Uncompress allows only a single outgoing connection
Properties
Property
Name
Passwords
A list of passwords for opening password-protected archives; each of the passwords in the list will be tried in turn.
The script expression can be used to determine a password dynamically, for example based on the sender of the packed data.
Note: The result of the script expression evaluation must be a string containing one password or a list of passwords separated by a newline character ('\n').
Example:
var thePasswords = new Array();
thePasswords.push( "password" );
thePasswords.push( "password2" );
thePasswords.join( '\n' );
Remove redundant folders
If set to Yes, for archives where the files or job folders are contained in deeply nested subfolder structures, removes all but the deepest subfolder level while uncompressing
Example: A PDF file that is compressed as "Folder 1\Folder 2\Folder 3\Test.pdf" is uncompressed as "\Folder3\Test.pdf", if this option is enabled.
Note: The Uncompress tool cannot read passwords which have been encrypted using the AES encryption. Switch uses zlib which does not support the AES encryption. As a workaround, users can try using a third party archiver as a command line application from Switch.
