XMP pickup
XMP pickup is a processor that allows associating an XMP packet with a job as metadata. It supports the following pickup mechanisms:
Keywords
The keywords for the XMP pickup element are:
Data model
The metadata source must be an Adobe XMP packet or a standalone XMP file conforming to the Adobe XMP specification dated June 2005. The dataset data model is XMP.
Connections
XMP pickup allows only a single outgoing connection.
Properties
Property
Name
Dataset name
A name for the set of metadata picked up by this tool; see picking up metadata
Pickup mode
The pickup mechanism; one of:
  • Metadata embedded in asset
  • Metadata alongside asset
  • Metadata in job folder asset
  • Metadata is asset
Additional properties are shown depending on the selected pickup mode; see Pickup modes for more information.
Locating XMP packets
The mechanism for embedding XMP packets in a file is also described in detail in the Adobe XMP specification mentioned above.
There are two distinct methods to locate XMP packets embedded in a file:
The XMP pickup tool interprets the file format for a number of supported file formats, and scans the complete file for all other file formats.
Synchronizing with EXIF and IPTC
For certain supported file formats the values of binary EXIF and IPTC tags can be merged with the embedded XMP packet before it is picked up. See the "Synchronize EXIF/IPTC fields" property for the embedded pickup mechanism.
