Activating Switch (online method)
Once you have installed Switch, you must activate the modules for which you have a license.
Note:
  • You need at least a license for the Switch Core Engine. Other modules are optional.
  • If you’re using a firewall, make sure to allow Switch to communicate with https://licensingservices.esko.com using ports 80 and 443.
This procedure describes how to activate Switch on a computer with internet access.
To activate Switch
  1. Start Switch and connect to the local Switch Server. Activation is only possible on a local Switch Server. The Enfocus Software Activation dialog appears.
  2. Make sure the Off-Line Mode checkbox is cleared.
  3. Enter your account name and password. If you don't have an Enfocus activation account yet, click the Create account link. After completing the form, you will receive an email with an account name and password.
  4. To supply your product key(s), do one of the following:
    • Enter the product keys in the text area.
    • Drop the product key file into the text area.
    • Click Browse to select the product key license file from a location on your local system.
    A green check mark next to the product key indicates that the key is valid.
  5. Click Activate. In the right part of the dialog, a green checkmark appears next to the activated module(s).
  6. Click Close.
