After you have created a flow, you can still make a number of changes. You can for
example:
Rename the flow.
Add a background and/or a header image.
Tune the performance of Switch, by overruling a number of default settings
for concurrent job processing (Refer to Allowing advanced
performance tuning in Flow properties).
To change the flow properties
In the Flows pane, select the flow of which you want to change the
properties.
Note: Make sure that none of the flow elements in the canvas are selected.
Otherwise, you might see the properties of the element, rather than the
properties of the flow.
The properties of the selected flow are displayed in the Properties pane.
Click the property you want to change.
Depending on the selected property, a text box, a button, or a drop-down
menu appears.
Make the required changes:
If ... appears
Do the following:
A text box
Type the text in the displayed text field.
A drop-down menu
Select the appropriate option.
1. In the the property editor dialog that pops up, update the
field(s) as required.
2. Click OK.
1. From the pop-up list, select one of the options.
Depending on the selected option, an inline editor or a dialog
appears.
2. Configure the desired values.
For an overview of the properties and their meaning, see Flow properties.
