To set the SwitchClient Switch server preferences
Go to .
In the User preferences pane, click Switch
Server.
In Refresh interval, specify the time interval (in
minutes) for refreshing the information displayed in SwitchClient.
In Information period, specify the time (in hours) when
a processed job card should be removed from the job list.
In the File transfer drop down menu, choose the type of
file transfer you want to use:
If you want files to be uploaded in a sequential manner maintaining the
order the of the jobs, select First in first out.
This method is slower as only one thread is used for uploading.
If you want files to be uploaded at a faster pace, select
Faster transfers.
Files are uploaded without any specific order (smaller files are
usually uploaded first). This method is faster as two threads are used
for uploading.
