The following table describes the columns in the Messages pane. You can resize and reorder the columns by dragging the column headers.
Column |
Time stamp |
The moment in time when this message was issued |
Type |
The message type, such as Info or Error (see below) |
Module |
The Switch module (such as Control) or type of flow element that issued this message |
Flow |
The name of the flow issuing this message |
Flow element |
The name of the flow element issuing this message |
Job Prefix |
The unique name prefix of the job referred in the message, or blank if there is no unique name prefix |
Job |
The name of the job for which this message was issued |
Message |
The message itself |
Type |
Info |
An informational message that has no other purpose than to inform the user of a certain occurrence. Info messages are only shown in the Messages pane when they relate to Switch Server. Info messages related to Switch Designer (i.e. to jobs or flow elements) can still be viewed by enabling the Log to CSV file preference; by doing so, they will be included in the log files. Refer to Switch preferences: Logging. |
Warning |
A warning message that informs the user of a recoverable problem or non-fatal error. Warnings are always shown in the Messages pane. |
Error |
An error message that informs the user of a fatal error. Errors are always shown in the Messages pane. |
Debug |
An informational message solely intended for debugging purposes (often generated by configurators). Debug messages are never shown in the Messages pane. They can still be viewed by enabling the Log to text file preference; by doing so, they will be included in the log files. Alternatively, you can view debug messages in the web browser view, by enabling the Log debug message preference. Refer to Switch preferences: Logging. |
Assert |
A message solely intended for debugging purposes that is issued only when a coding error is discovered. Assert messages are never shown in the Messages pane. They can still be viewed by enabling the Log to text file preference; by doing so, they will be included in the log files. Alternatively, you can view assert messages in the web browser view, by enabling the Log debug message preference. Refer to Switch preferences: Logging. |
