Feature matrix
The following table indicates what you can do in Switch, depending on the activated modules:
Feature
Switch Core Engine Config module Metadata module Scripting module Switch Client module
Switch Server and Designer
Flow design (flow wizard, canvas, flows pane, elements pane, properties pane, ...)
Flow execution (feedback on canvas, messages pane, dashboard pane, statistics pane)
Built-in tools (see Flow elements matrix)
Configurators for third-party applications
Hierarchy info and email info (internal metadata)
Variables and read-only embedded metadata (EXIF, IPTC, XMP)
Writing and updating external Xpath-based metadata (XMP)
External metadata (XML, JDF) and writable embedded metadata
Script expressions and script elements
Script development environment (SwitchScripter)
Scripted plug-ins (if licensed by Enfocus)
Setup for SwitchClient (users pane, Submit point, Checkpoint)
Connections to SwitchClient
