Switch Server name |
The name of this instance of the Switch Server. This name will be shown to users of SwitchClient. It is also used in the title bar of the application and in the file name of exported logs. If you're launching your log messages in a web browser, this name is also displayed in the title of the web page. Note: Changing the server name requires a restart of
Switch.
Port for Switch Designer |
The port used for communication between Switch Server and Switch Designer, in the range of 1 to 65535. |
Port for SwitchClient |
The port used for communication between Switch Server and SwitchClient instances, in the range of 1 to 65535. |
Port for Watchdog - Switch Server |
The port used for communication between Switch Server and Switch Watchdog, in the range of 1 to 65535. |
Port for Watchdog |
The port used for communication between Switch Designer and SwitchClient Watchdog, in the range of 1 to 65535. The following options are only available if you have licensed SwitchClient. |
| Allow older clients to connect (less secure) |
To protect Switch against the Heartbleed Bug (a leak in OpenSSL), as of Switch 12 update1, Switch Server uses new, secure SSL certificates for the HTTPS communication with Switch Clients, Enfocus Connectors and Switch Designer. We recommend upgrading to SwitchClient 12 update 1 (or later) or Enfocus Connect 12 (or later). You must recreate the Connectors in order to use the new certificates. However, if you want to establish the communication with older client applications (released before Switch 12 update 1), you can still use the old certificates, by setting this preference to Yes. In that case, be aware that the connections are less secure. Note: Keep in mind that all connections (to old and new
clients) use the old certificates.
If set to No (default), the Switch Server uses the new, secure SSL certificates for HTTPS communication with Switch Clients, Enfocus Connectors and Switch Designer. |
| Compress SwitchClient jobs |
If set to Yes (default), jobs transferred from and to SwitchClient instances are compressed (resulting in higher processing time and lower bandwidth consumption). If set to No, jobs are not compressed (resulting in lower processing time and higher bandwidth consumption); this option is meaningful for high-speed local networks. |
