Pack job
Pack job is a processor that packs a job and its associated metadata for transmission. The result is always a single ZIP file that contains a globally unique identifier to identify it across multiple Switch instances.
Pack job also stamps the internal job ticket of its output with the unique identifier so that confirmations can be matched with the packed data without opening the ZIP file.
See Acknowledged job hand-off for an example of how to use this tool.
Keywords
If you enter one of the following keywords in the Search field at the top of the Flow elements pane, the FTP receiv Pack job element will be shown in the list:
Connections
Pack job allows only a single outgoing connection.
Properties
Property
Name
Include internal metadata
If set to Yes, the output archive contains internal job ticket information for the job (including e-mail info, hierarchy info, private data fields, etc.).
Include external metadata
If set to Yes, the output archive contains a copy of the external metadata (that is, all datasets) associated with the job.
Embedded metadata is always included since it is part of the job file itself.
Compress
If set to Yes, the data in the output archive is compressed (the default behavior).
If set to No, the data is stored in the output archive without compression, dramatically reducing processing time; this can be meaningful when speed is more important than size, or when the data does not compress well (as is the case for JPEG images).
Password
The password used for protecting the output archive, or empty if no password protection should be used.
