These preferences allow you to configure some aspects of the Switch user interface.
Designer Language |
The language of the user interface of the Switch Designer. You can select one
of the following languages:
Note:
Large icons in elements pane |
If set to Yes, the Flow elements pane displays large icons; otherwise it displays small icons. |
| Start Switch Server automatically at login |
When exiting the flow designer |
This option is only available if Start Switch Server automatically at login is set to No. It determines what happens to the Switch Server when the user quits Switch Designer: Note: This preference is taken into account only in case there
are currently active flows; otherwise Switch Server
always exits disregarding the preference value.
Options:
