If a new version is available, you can update the app for free (but you are not
obliged to do so). You can also downgrade as required.
Proceed as follows:
Do one of the following:
When a new version of an app is available, you will get a notification
in Switch. To get more information about this new version, click the
notification.
Alternatively, go to the My Apps page in the Enfocus Appstore.
Search the app concerned, and click Change version beside its
name.
The Change Version page appears.
Select the version you would like to install.
Check the release notes and the compatibility section on the lower part of the
page.
If you're sure you want to install the new version, click Change
version.
If Switch is running, click the Refresh apps
button in the top right corner of
the Flow elements pane. This will update the app in your local Switch.
If Switch is not running, next time time you log into Switch, the app is
updated automatically in the background. You don't have to do
anything.
In Switch, you'll see a dialog with information about the version
change.
Click OK.
You can still cancel the update if necessary.
All flows are temporarily deactivated, the app is updated, and finally
the flows are re-activated automatically. You can go on using the updated
version of the app.
