 Note that this view can be
customized to your needs.
- To remove a column, drag the column header
upwards or downwards.
- To move or sort the columns, drag them
sideways.
- To show or hide columns, select Show
Columns from the context menu in the
column header and select or deselect the columns
as required.
- To group jobs in a multi-level tree based on the
columns, select Group by
column header and select the appropriate column.
The order in which the columns are checked is the
order of the grouping.
If the Filters pane is used in the Table
view, the layout (that is, column ordering and the
columns that are hidden or visible) are remembered
together with the filter.
