应用程序 AppleScripts 示例
打开脚本:使用文档首选项
要使用文档首选项来打开一个文档,将如下内容指定为自定义的"打开"脚本并在第一个参数中输入"yes"。
on run {args}
  set theJobPath to infile of args
  set theDocPrefs to arg1 of args
  set scriptResult to "/OK/"
  tell application "QuarkXPress"
    try
      if (theDocPrefs is equal to "yes") then
        open alias theJobPath use doc prefs yes remap fonts no do auto picture import no
      else
        open alias theJobPath use doc prefs no remap fonts no do auto picture import no
      end if
    on error errmsg number errnum
      set scriptResult to ("/ERROR/:" & errmsg)
    end try
  end tell
  return scriptResult
end run
命令脚本:颠倒文档中的页面顺序
要颠倒文档中的页面顺序,将如下内容指定为自定义的"命令"脚本。该脚本不使用任何参数。
on run {args}
    try
      if not (exists document 1) then error "No open document"
      tell document 1
        set pageCnt to count of page
        if pageCnt is not equal to 1 then
          repeat with i from 1 to pageCnt
            move page pageCnt to before page i
          end repeat
        end if
      end tell
    end try
  end tell
  return scriptResult
end run
另存为脚本:保存为多文件 DCS
要将一个文档保存为多文件 DCS,将如下内容指定为自定义的"另存为"脚本(使用一个编译好的脚本)。该脚本使用第一个参数指定色彩设置项("灰度"、"复合 RGB"、"复合 CMYK"、"复合 CMYK 和专色"、"保持原样")。
on run {args}
  set theOutputSetup to arg1 of args
  set theResultJobPath to "/ERROR/:Unknown error"
  using terms from application "PowerSwitch_Service"
    tell application (server of args)
      try
        set theJob to jobobject of args
        set theJobProper to proper name of theJob
        set theResultJobPath to create path theJob name theJobProper with creating folder
        set theResultJobPath to ("/ERROR/:" & errmsg)
        return theResultJobPath
      end try
    end tell
  end using terms from
    try
      tell document 1
        set pageCnt to count of pages
        repeat with i from 1 to count of pages
          -- Create the sequential number for the file
          set fileNum to i
          repeat until (length of (fileNum as text)) = (length of (pageCnt as text))
            set fileNum to "0" & fileNum
          end repeat
          set FileName to theJobProper & "_" & fileNum & ".eps"
          set theResultPath to theResultJobPath & ":" & FileName
          save page i in theResultPath EPS format Multiple File DCS EPS data binary EPS scale 100 Output Setup theOutputSetup with transparent page
        end repeat
      end tell
      close document 1 without saving
    end try
  end tell
end run
