Process these folders
The objective is to offer more flexibility for defining the subset of the folder hierarchy to be processed. This is accomplished by offering a variable list of powerful rules.
Properties
The tool offers the following new properties:
Property name Description Editors Default
Process these folders Defines the ‘initial' set of folders that should be processed by the submit hierarchy tool; this set can be adjusted by defining one or more rules in subsequent properties
Possible values are:
  • All folders
  • No folders
Dropdown list All folders
Adjusted by (rule 1) Defines a rule for adjusting the set of folders that should be processed by including or excluding folders
  • Including folders named
  • Including folders not named
  • Excluding folders named
  • Excluding folders not named
Dropdown list None
.. Folder name A pattern for the folder name to be included or excluded Folder patterns Regular expression Script expression Empty
.. On levels The level or range of levels to which this rule applies, in the same format as the old "Subfolder range" property Single-line text Empty
.. Restriction Defines an optional restriction on the parent or ancestors for the folder in this rule
Possile values are:
  • None
  • With immediate parent named
  • With no immediate parent named
  • With any ancestor named
  • With no ancestor named
Dropdown list None
.... Parent name or
.... Ancestor name
A pattern for the folder name of the parent or ancestor Folder patterns Regular expression Script expression Empty
.. Nesting
Defines whether this rule operates on subfolders of the target folder, which are deeper in the hierarchy than the defined level range. The matching rule is also applied on these subfolders.
Possible values for "including" rule are:
  • Include nested subfolders as well
  • Don't include nested subfolders
Possible values for "excluding" rule are:
  • Exclude nested subfolders as well
  • Dont exclude nested subfolders
Dropdown list "Don't include…" or "Exclude…"
Adjusted by (rule 2)
Adjusted by (rule 5)
Same as rule 1 with an identical set of dependent properties
Applying rules
The rules are applied in the same order as they are specified. It is perfectly possible for a rule to exclude folders that were included by a previous rule, or vice versa.
For example, consider a hierarchy with two levels (in addition to the root folder) and where each level has three folders called A, B, C. Now, consider the following rules:
  • Start with no folders
  • Include folders named C on level 2 (with or without nesting)
  • Exclude folders named C on level 1 (with nesting)
These rules will process all jobs in folders A/C and A/B, but not in folder C/C (because it was excluded in the second rule), and not in any of the other folders (because they were never included to begin with).
Reversing the order of the rules would change the result (files in folder C/C will be processed as well), because excluding something from an empty set has no effect.
Upgrading
When upgrading from a previous version of Switch, the new properties are initialized as follows:
  • The new "Process these folders" property is set to "All folders"
  • If the old "Process only these folders" property is not set to "All folders", a rule is created as indicated in the following table
  • If the old "Skip these folders" property is not set to "No folders", a rule is created as indicated in the following table
If both old properties are present, the rules are listed in the order presented above (although the order is not important).
Property name Value for "Process only these folders" Value for "Skip these folders"
Adjusted by "Excluding folders not named" "Excluding folders named"
.. Folder name The value of the "Process only these folders" property
The value of the "Skip these folders" property
.. On levels The value of the corresponding dependent property The value of the corresponding dependent property
.. Restriction "None" "None"
.. Nesting "Exclude nested subfolders as well" "Exclude nested subfolders as well"
These values should produce the same behavior as in the previous Switch version.
