If you have an active license for the Scripting Module, you have access to the Script element in the Flow elements pane. This allows you develop your own scripts (using the SwitchScripter application, which comes with Switch), for example to extend the capabilities of Switch. You can also create your own configurator(s) using SwitchScripter, for interaction with third-party applications that are not yet supported by Switch.
For more information, refer to the Switch Scripting documentation on the Enfocus website. There is also a guide with sample scripts available on the Enfocus website.
