About working with flows in Switch
Working with flows consists of the following steps:
  1. First you have to create a new flow. You can start from scratch (blank flow) or from a sample flow.
  2. Next, you have to design your flow, by dragging the required flow elements to the canvas. You must configure the properties of the different flow elements and connectors.
  3. Finally, you must activate the flow, and test it, using test files, until you are happy with the result.
For a step by step explanation, refer to the Switch Quick Start Guide on the Enfocus website.
For a detailed description of everything you can do with Switch flows, refer to the topics below.
