Activating Switch
Once you have installed Switch, you must activate the application.
Trial version
If you want to try the application before you buy it, you can activate a trial version. A trial version remains active for 30 days.
The Switch Core Engine doesn't have a built-in trial version; contact your local Enfocus reseller and request a trial version. You will receive a license key which can be activated in the same way as a purchased license (see further).
The Switch additional modules do have a built-in trial version. Once you have activated the Switch Core Engine, you can activate trial versions of the other modules, without having to contact a reseller. Refer to Activating a Switch trial for additional modules (online method) or Activating a Switch trial for additional modules (offline method).
Licensed version
If you have bought the application, you can activate the modules for which you have a license:
Remember that you can only activate licenses with a local Designer. When using Remote Designer, you can view the license information, but you cannot change it.
