Licenses
A regular SwitchClient Module includes a license for
up to
five concurrent connections. If this is not sufficient, you can purchase additional
licenses. The number of licenses can be raised by entering a new activation key in the
Manage licenses dialog in Switch.
An active SwitchClient Module allows
you access to the following flow elements:
- Submit point
- Checkpoint
- Checkpoint via mail
If SwitchClient is not licensed, the above flow elements will not be available and you will
not be able to submit and check jobs through the Switch Web Portal.
How to proceed
Follow the guidelines and instructions described in the chapter on installing, activating and starting Switch.
- Install Switch.
- Activate Switch, including the SwitchClient Module.
- Activate additional licenses if required.
