Connection group
These variables are Switch-specific. They provide access to the attributes of the client connection. The third column indicates the scripting API function that returns the variable's dynamic value.
Variable name Data type Scripting API equivalent
Connection.Email Text ClientConnection.getEmail()
Connection.UserName Text ClientConnection.getUserName()
Connection.FullUserName Text ClientConnection.getFullUserName()
Connection.IP Text ClientConnection.getIP()
Note: The variables from this group are valid only in context of a client connection. Please refer to the note in the description of the method Environment.getClientConnection(). When used without an active client connection, the Connection variables will return empty values. This amounts to the empty string for Text variables and 0 for Integer variables.
