Execute command is a tool that executes a system command or a console application with the specified command-line arguments and output mechanisms.
The keywords for the Execute command element are:
Execute command allows only a single outgoing connection
Properties |
Name |
| Execution Mode | This property helps you to configure the tool to handle jobs in parallel (concurrent) or
serial mode:
Command or path |
The system command to be executed (only allowed for commands from the
operating system!), or the absolute path to the console
application to be invoked.
Note: If you don't know the location
of the application, search for it in the documentation of
the application or search for the application on your disk.
On Windows, applications are usually installed under
C:\Program Files\ or C:\Program Files (x86)\. On Mac, you
can use Spotlight to search in the system files (see http://support.apple.com/kb/HT4355) .
Arguments |
The remainder of the command line; the following substitutions are made in the specified text:
All of these substitutions work even if "Output" is set to None or Original (in which case any generated output is discarded) Placeholders (%1, %2, %3) and argument values that may contain spaces (such as file paths) must be enclosed in quotes! |
Output |
Determines how the command generates its output (the tool automatically moves the output to the outgoing connection):
Copy input job |
If set to yes, the incoming job is copied to a temporary location before the command is triggered; this must be turned on in cases where the command modifies the input job or places files in the folder where the input job resides This property is not present for some choices of output because in those cases the incoming job must always be copied |
Output job filter |
Determines which of the generated files or folders is the output file; Automatic works unambiguously if a single file is generated; otherwise a simple heuristic is used to make an "educated guess" |
Output extension |
The filename extension of the output job to be provided to the command line (i.e. the substitution of %2); Automatic means use the same extension as the input job |
Fail if exit code is |
Fails the job (that is, moves it to the problem jobs folder) if the command's exit code is:
Range |
A range specified as "n1..n2;n3..n4" where the n's represent a positive or negative integer or are missing to indicate an open end; for example: "-7..-4; 0.." |
Fail if stdout contains |
Fails the job (that is, moves it to the problem jobs folder) if the regular console output contains the search string or pattern; empty means disregard the regular console output |
Fail if stderr contains |
Fails the job (that is, moves it to the problem jobs folder) if the console error output contains the search string or pattern; empty means disregard the console error output |
We recommend creating a working command in Command Prompt on Windows or Terminal on Mac first, before actually configuring the Execute command flow element.
Keep in mind that Switch will execute the command directly in the operating system while Command Prompt and Terminal use a shell. This results in some differences in behavior, the most important one being that you always have to provide the full path to the command line application in Switch, even when this is not necessary in Command Prompt or Terminal!
For complex issues, it may be handy to enable the logging of debug messages (see Switch preferences: Logging). The table below gives an overview of the debug messages that will be logged when running the Execute Command Tool:
| Debug message | Meaning |
| Executing | Complete command which Switch will execute after it replaced the placeholders with the actual paths. |
| Outcode | The outcode/exitcode of the command. Switch decides whether or not the command was successful. |
| Stdout | Output of the command in case executing the command went well. This is the same output as you would see when executing the command in Command Prompt or Terminal. |
| Stderr | Output of the command in case of problems. This is the same output as you would see when executing the command in Command Prompt or Terminal. |
If none of the above debug messages are generated, the operating system failed to execute the command itself. Check if the path to the application is correct and check if you have the right permissions.
Redirecting output from a command to a text file is a feature of the shells used in Terminal and Command Prompt and is therefore not possible using the Execute command tool in Switch.
As a workaround, you can create a batch file that uses a shell that supports redirecting. Use this batch file as a command and send input and output paths as arguments to this batch file.
Example:
Setup of the Execute Command Element:
Contents of the script.sh batch file:
#!/bin/bash
sed "s/\&/\&/g" "${1}" >> "${2}" (This example will replace “&” with “&” in text files)
Command or path: cp
Arguments: Script expression defined:
"var destPath = "/Users/user/Desktop/dest";
var path = job.getPath();
var command = "\"" + path + "\" \"" + destPath + "\"";
command;"
Command or path: C:/Program Files/Application /Application 1.0/Application/Application.exe Arguments: /t "%1" "option with space" "option with space" TASKKILL /IM "Application.exe" <-- WRONG -->
C:\Users\user>dir "c:\folder1\folder2" taskkill /im Application.exe <-- WRONG -->
C:\Users\user>dir "c:\folder1\folder2" <-- CORRECT --> C:\Users\user>taskkill /im Application.exe <-- CORRECT -->
Command or path: tar Arguments: -zxvf "%1" -C "%3"
dir c:/folder/inner folder <-- WRONG --> dir "c:/folder/inner folder" <-- CORRECT -->
Preferably, use a bat file/shell script instead of an executable or an app.
Content of the shell script: #!/bin/bash export PATH="$PATH:/cygdrive/c/Program Files/MySQL/MySQSL Server 5.7/bin" echo $PATH #do everything that you want #start your application for example mysql $1 Command or path: <path to bash> Arguments: <path to sh> <mysql arguments>
