Export metadata is a processor that allows saving a metadata dataset associated with the incoming job to a standalone file. The tool merely copies the dataset's backing file to the output location without any transformations. The XSLT transform tool can be used to transform the exported metadata if needed.
The outgoing log connections carry the exported metadata; the outgoing data connections carry the incoming job without change. If the incoming job has no dataset with the specified name, no log output is generated.
The keywords for the Export metadata element are:
Export metadata supports any number of outgoing traffic-light connections.
Name |
Dataset name |
The name of the set of metadata (associated with the job) to be exported; see Picking up metadata for more information |
Filename body |
The filename for the generated metadata file (without filename extension) |
Filename extension |
The filename extension for the generated metadata file; select "Data Model" to automatically use "xml", "jdf" or "xmp" depending on the data model of the exported dataset (for the Opaque data model, the original backing file's filename extension is used) |
