Formatting
The following table describes the formatting options for each data type, including:
Data type
Description of data type /Formatting argument
Representation as a text string
Text
Text string
Text string
Alt Text
Possibly localized text string
Text string (Switch always uses the default language)
Text Indexed
List of items of type Text
See indexed variables
Boolean
Boolean value true or false
"True" or "False" (or all-lower-case versions)
Integer
Integer number
Decimal representation (including minus sign if needed; no plus sign; no leading zeroes)
Rational
Rational number formed by division of two integers
Decimal representation of the form: numerator, forward slash, denominator; example: "2/3" or "-17/4"
Precision="integer"
Decimal floating point representation with the specified number of digits after the decimal point (minimum precision is 1, max is 15)
Date
A moment in time, including date and/or time information
String representation in the subset of the ISO 8601 format allowed in XMP Date fields (see Adobe XMP specification, version dated September 2005, page 75)
Equivalent to format string "yyyy-MM-ddThh:mm:ss.zzz"
Format="format-string"
String representation in the format specified by the format string, which must conform to the syntax described below
Date format string
The following format expressions are recognized and replaced in the date format string:
Expression
Output
d
the day as number without a leading zero (1 to 31)
dd
the day as number with a leading zero (01 to 31)
ddd
the abbreviated day name (example: 'Mon' to 'Sun')
dddd
the long day name (example: 'Monday' to 'Sunday')
M
the month as number without a leading zero (1-12)
MM
the month as number with a leading zero (01-12)
MMM
the abbreviated month name (example: 'Jan' to 'Dec')
MMMM
the long month name (example: 'January' to 'December')
yy
the year as two digit number (00-99)
yyyy
the year as four digit number
h
the hour without a leading zero (0 to 23 or 1 to 12 if AM/PM display)
hh
the hour with a leading zero (00 to 23 or 01 to 12 if AM/PM display)
m
the minute without a leading zero (0 to 59)
mm
the minute with a leading zero (00 to 59)
s
the second without a leading zero (0 to 59)
ss
the second with a leading zero (00 to 59)
z
the milliseconds without leading zeroes (0 to 999)
zzz
the milliseconds with leading zeroes (000 to 999)
AP
use AM/PM display; AP will be replaced by either "AM" or "PM"
ap
use am/pm display; ap will be replaced by either "am" or "pm"
any sequence of characters enclosed in single quotes is treated as literal text
See also:
