Metadata group
These variables allow access to an arbitrary field in any dataset associated with the job (external metadata or embedded metadata).
There is a variable for each data type supporting the appropriate formatting and/or indexing arguments. This enables the user to express the expected data type for the metadata value and control its formatting.
Variable name
Data type
Metadata.Text
Text
Metadata.TextIndexed
Text Indexed
Metadata.Boolean
Boolean
Metadata.Integer
Integer
Metadata.Rational
Rational
Metadata.Date
Date
Selecting a data field
The variables in the Metadata group support the following arguments for selecting a particular metadata field from a particular dataset.
Argument
Value
Dataset
The name of the external dataset to be accessed, or empty/missing to indicate the embedded dataset
Model
The data model used for querying the data set; when empty/missing the data model is derived from the dataset; allowed values are "XML", "JDF" and "XMP"
This argument can be omitted except when forcing a JDF data model to be queried using regular XML semantics (that is, using "evalToString" rather than "getString")
Path
The location path or expression for selecting a field (or calculating a value) using syntax appropriate for the data model:
  • XML: XPath expression (which includes XPath location paths)
  • JDF: JDF location path (which is really the same as an XPath location path)
  • XMP: XMP location path
  • All prefixes used in the location path or expression must occur in the default namespace map for the data set; there is no way to specify explicit mappings.
    Make sure to use the correct prefix:
    For the XML data model, use the prefix "dn", for example:
    [Metadata.Text:Path="/dn:XML/dn:ResourcePool/dn:CustomerInfo/@DescriptiveName",Dataset="Xml",Model="XML"]
    For the JDF data model, use the prefix "jdf", for example:
    [Metadata.Text:Path="/jdf:JDF/jdf:ResourcePool/jdf:CustomerInfo/@DescriptiveName",Dataset="Jdf",Model="JDF"]
    For more information, refer to "XML data model" and "JDF data model" in the Switch Scripting Guide, available on the Enfocus website.
Data type conversions
Switch does not guarantee that the value of a variable in the Metadata category conforms to the string representation of its data type. The user is responsible for selecting the correct data type by using the appropriate variable in the Metadata category.
The variable is always set to the string value of the query (for Text Indexed, each item in the list is converted separately).
In other words:
