These variables access metadata fields embedded in Microsoft Office documents (Excel files, Word documents, PowerPoint presentations).
Variable name |
Data type |
| Office.Application | Text |
Name of the application that created the document, for example: Microsoft Office Word |
| Office.AppVersion | Text |
Version of the application that created the document; string of the form XX.YYYY (X and Y representing numerical values), for example: 14.0000 |
| Office.Author | Text | Author of the document |
| Office.Category | Text | Category of the document |
| Office.Company | Text |
Name of a company associated with the document |
| Office.ContentStatus | Text | Status of the document content, for example: Draft, Reviewed, Final, ... |
| Office.ContentType | Text | Type of document content, for example: Whitepaper, Security Bulletin, Exam, ... |
| Office.Created | Date | Date and time when the document was created, for example: 2014-02-05T10:10:36.000Z. You can modify the format, for example: dd:MM:yy mm:ss (UTC time zone) will result in 05:02:14 10:36 |
| Office.Custom | Text |
The metadata value selected from the document using XPath expression provided in the 'Path' argument. The argument 'Set' defines the metadata set where the required value is searched for. The possible values for the 'Set' argument are 'Core' and 'Extended' (used as the default value). For more details, refer to the section below. |
| Office.Description | Text | Textual description of the document |
| Office.DocSecurity | Integer |
Security level of the document:
| Office.HyperlinkBase | Text |
Base string used for evaluating relative hyperlinks in this document |
| Office.HyperlinksChanged | Boolean |
Indicates whether or not hyperlinks were changed:
| Office.Identifier | Text | Identifier of the document |
| Office.Keywords | Text | Keywords that specify the topic of the document |
| Office.Language | Text | Language of the document |
| Office.LinksUpToDate | Boolean |
State of the hyperlinks in the document:
| Office.Manager | Text | Name of a supervisor associated with the document |
| Office.Modified | Date | Date and time when the document was last modified |
| Office.ModifiedBy | Text | Author of the last modification in the document |
| Office.NumberOfCharacters | Integer |
Total number of characters in the document |
| Office.NumberOfCharacters WithSpaces |
Integer |
Last count of the number of characters (including spaces) in this document |
| Office.NumberOfHiddenSlides | Integer |
Number of hidden slides in the presentation |
| Office.NumberOfLines | Integer |
Total number of lines in the document when last saved by a conforming producer |
| Office.NumberOfMMClips | Integer |
Total number of sound or video clips that are present in the document |
| Office.NumberOfNotes | Integer |
Number of slides in the presentation containing notes |
| Office.NumberOfPages | Integer |
Total number of pages in the document |
| Office.NumberOfParagraphs | Integer |
Total number of paragraphs found in the document |
| Office.NumberOfSlides | Integer |
Total number of slides in the presentation |
| Office.NumberOfWords | Integer |
Total number of words in the document when the document was last saved |
| Office.PresentationFormat | Text |
Intended format for the presentation, for example a presentation intended to be shown on video has PresentationFormat Video, a presentation to be shown on screen, could have On-screen (4:3), ... |
| Office.Printed | Date | Date and time when the document was last printed |
| Office.Revision | Integer | Revision number |
| Office.ScaleCrop | Boolean |
Display mode of the document thumbnail:
| Office.SharedDoc | Boolean |
Indicates whether or not the document is shared:
| Office.Subject | Text | Subject of the document |
| Office.Template | Text | Name of an external document template containing format and style information used to create the document. |
Office.Title |
Text |
Title of the document |
| Office.TotalTime | Integer | Total time that the document has been edited. The default time unit is minutes. |
| Office.Version | Integer | Version number |
Use this variable if there is a metadata tag in your Office document that does not have a dedicated Switch variable. The [Office.Custom] variable allows you to retreive the value of this tag, on condition that you have the correct XPath expression. Note that the data type of this variable is 'Text', so only text manipulation arguments are available for it.
The metadata value is selected from the document using the XPath expression provided in the Path argument. All prefixes used in the expression must occur in the default namespace map for the metadata XML file. There is no way to specify explicit mappings. The default namespace is automatically available using prefix 'dn'.
Examples
[Office.Custom:Path="/dn:Properties/dn:Application"] - This gives the same result as [Office.Application] [Office.Custom:Path="/dn:Properties/dn:TitlesOfParts/vt:vector/vt:lpstr[1]",Set="Extended"] - The title of some document part [Office.Custom:Path="/cp:coreProperties/dc:title",Set="Core"] - This gives the same result as [Office.Title]
More information about the Office Open XML format and its metadata can be found here: http://en.wikipedia.org/wiki/Office_Open_XML_file_formats.
