Photo group
These variables access embedded metadata fields in the EXIF format (synchronized with Adobe XMP). The third column indicates the hexadecimal EXIF tag corresponding to each variable.
Variable name
Data type
XMP location path
EXIFF tag
Photo.ApertureValue
Rational
exif:ApertureValue
0x9202
Photo.BrightnessValue
Rational
exif:BrightnessValue
0x9203
Photo.ColorSpace
Integer
exif:ColorSpace
0xA001
Photo.CompressedBitsPer Pixel
Rational
exif:CompressedBitsPerPixel
0x9102
Photo.Contrast
Integer
exif:Contrast
0xA408
Photo.CustomRendered
Integer
exif:CustomRendered
0xA401
Photo.DateTimeDigitized
Date
exif:DateTimeDigitized
0x9004 & 0x9292
Photo.DateTimeOriginal
Date
exif:DateTimeOriginal
0x9003 & 0x9291
Photo.DigitalZoomRatio
Rational
exif:DigitalZoomRatio
0xA404
Photo.ExposureBiasValue
Rational
exif:ExposureBiasValue
0x9204
Photo.ExposureIndex
Rational
exif:ExposureIndex
0xA215
Photo.ExposureMode
Integer
exif:ExposureMode
0xA402
Photo.ExposureProgram
Integer
exif:ExposureProgram
0x8822
Photo.ExposureTime
Rational
exif:ExposureTime
0x829A
Photo.FlashEnergy
Rational
exif:FlashEnergy
0xA20B
Photo.FlashFired
Boolean
exif:Flash/exif:Fired
0x9209 bits
Photo.FlashFunction
Boolean
exif:Flash/exif:Function
0x9209 bits
Photo.FlashMode
Integer
exif:Flash/exif:Mode
0x9209 bits
Photo.FlashRedEyeMode
Boolean
exif:Flash/exif:RedEyeMode
0x9209 bits
Photo.FlashReturn
Integer
exif:Flash/exif:Return
0x9209 bits
Photo.FNumber
Rational
exif:FNumber
0x829D
Photo.FocalLength
Rational
exif:FocalLength
0x920A
Photo.FocalLengthIn35mm Film
Integer
exif:FocalLengthIn35mmFilm
0xA405
Photo.FocalPlane ResolutionUnit
Integer
exif:FocalPlaneResolutionUnit
0xA210
Photo.FocalPlaneX Resolution
Rational
exif:FocalPlaneXResolution
0xA20E
Rational
exif:FocalPlaneYResolution
0xA20F
Photo.GainControl
Integer
exif:GainControl
0xA407
Photo.ImageUniqueID
Text
exif:ImageUniqueID
0xA420
Photo.ISOLatitude
Integer
exif:ISOSpeedRatings/*[2]
0x8827
Photo.ISOSpeed
Integer
exif:ISOSpeedRatings/*[1]
0x8827
Photo.Lens
Text
aux:Lens
Photo.LightSource
Integer
exif:LightSource
0x9208
Photo.MaxApertureValue
Rational
exif:MaxApertureValue
0x9205
Photo.MeteringMode
Integer
exif:MeteringMode
0x9207
Photo.PixelXDimension
Integer
exif:PixelXDimension
0xA002
Photo.PixelYDimension
Integer
exif:PixelYDimension
0xA003
Photo.Saturation
Integer
exif:Saturation
0xA409
Photo.SceneCaptureType
Integer
exif:SceneCaptureType
0xA406
Photo.SensingFunction
Integer
exif:SensingFunction
0xA217
Photo.Sharpness
Integer
exif:Sharpness
0xA40A
Photo.ShutterSpeedValue
Rational
exif:ShutterSpeedValue
0x9201
Photo.SpectralSensitivity
Text
exif:SpectralSensitivity
0x8824
Photo.SubjectDistance
Rational
exif:SubjectDistance
0x9206
Photo.SubjectDistance Range
Integer
exif:SubjectDistanceRange
0xA40C
Photo.UserComment
Alt Text
exif:UserComment
0x9286
Photo.WhiteBalance
Integer
exif:WhiteBalance
0xA403
