The FTP send and Mail send tools produce a log file with processing results. This log file is carried along the outgoing log connections.
This log file can be associated with the job as a metadata dataset by using a "data with log" connection (see the "Carry this type of files" property of traffic-light connections).
The processing results log file uses the XML data model with a simple schema without namespaces.
The XML document element name is "ProcessingResults". It contains a sequence of elements with a name and contents as described in the following table. If a data item is not applicable, the corresponding element may be missing.
Element name |
Data type |
Destination |
Text |
For FTP, the complete target URL for the job For Mail, the list of destination email addresses |
FlowElementName |
Text |
The name of the flow element that produced this log file (as displayed in the canvas) |
FlowElementType |
Text |
The type of the flow element that produced this log file (e.g. "FTP send" or "Mail send") |
FlowName |
Text |
The name of the flow (as displayed in the flows pane) containing the flow element that produced this log file |
JobArrivalStamp |
Integer |
The arrival stamp for the processed job as a signed integer number; a lower arrival stamp indicates a job that arrived in the flow earlier (and vice versa) Several jobs may have the same arrival stamp, for example when multiple jobs are generated from the same original job |
JobByteCount |
Integer |
The size in bytes of the processed job; if it is a job folder, all files in subfolders are included in the count, recursively |
JobExtension |
Text |
The processed job's filename extension, or the empty string if there is none |
JobFileCount |
Integer |
The number of files in the processed job, including all files in subfolders, recursively (folders and subfolders themselves do not contribute to the count) |
JobFiles |
Sequence of "File" elements |
A sequence of one or more "File" elements representing the files in the processed job in arbitrary order; each File element has the Text data type and contains the relative path of a file within the job (using a forward slash as path separator) Folders are NOT represented in this list |
JobIsFile |
Boolean |
True if the processed job is a single file, false otherwise |
JobIsFolder |
Boolean |
True if the processed job is a folder, false otherwise |
JobName |
Text |
The file or folder name for the processed job, including filename extension if present, but excluding the unique filename prefix |
JobNameProper |
Text |
The file or folder name for the processed job excluding filename extension and excluding the unique filename prefix |
JobOrigin |
Text |
An indication of the origin of the processed job before it was injected in the flow; for example, a Submit point writes the absolute path of the original job (on the client machine) in this field |
JobPath |
Text |
The absolute file or folder path for the processed job as it resided in the input folder before being processed, including unique filename prefix |
JobPriority |
Integer |
The job priority assigned to the processed job as a signed integer number |
JobUniqueName Prefix |
Text |
The unique filename prefix used for the processed job, without the underscores; for a job called "_0G63D_myjob.txt" this would be "0G63D" |
JobUserName |
Text |
The user name associated with the processed job, if any |
ProcessingEnded |
Date |
The date-time when the operation was completed (in the ISO 8601 format also used for Switch date variables) |
ProcessingStarted |
Date |
The date-time when the operation started (in the ISO 8601 format also used for Switch date variables) |
ServerAddress |
Text |
The name or IP address of the destination server |
ServerLoginName |
Text |
The user name used to login at the destination server |
ServerPort |
Integer |
The port of the destination server |
