Sort job
Sort job is a processor that offers various schemes for sorting incoming jobs across its outgoing connections depending on metadata associated with the jobs.
For each job the tool determines the value of the specified metadata field and compares this value with the names of the outgoing connections. If a match is found, the job is moved along that connection. Otherwise the job is moved along the outgoing data error connection, or if there is no such connection, it is moved to the problem jobs folder.
Keywords
The keywords for the Sort job element are:
Connections
Sort job supports outgoing traffic-light connections of the following types:
Properties
Property
Name
Scheme
Determines the scheme used to specify a metadata value:
  • Direct: use variables or a script expression to calculate a value
  • Location path
  • Key/value pair
Value
The value to be used for sorting the job
Dataset
The name of the metadata dataset to query; Default means the embedded dataset
Data model
The data model used for querying the dataset (one of XMP, JDF, XML); this must match the data model of the dataset except that XML can be specified to query JDF
Location path
The location path pointing at the value to be used for sorting the job (for XML this can be an arbitrary XPath expression)
Array location path
The location path pointing at the array containing the key/value pairs
Key name
The name of the key field
Key contents
The value of the key
Value name
The name of the value field
