Uncompress is a processor that extracts files from an archive in one of the following formats:
ZIP
RAR
MIME
Any files that are not recognized as an archive are passed through the Uncompress tool without change.
The keywords for the Uncompress element are:
The following table describes the resulting file or folder structure and the corresponding naming conventions.
Multiple files from the same archive are always placed in a job folder. If the intention is to inject these files into the flow as separate jobs, a job dismantler should be placed directly after the uncompress flow element.
Archive contents |
Uncompress result |
Single file |
The file (named as specified in the archive). |
Multiple files or folders with a common root folder |
A job folder (named as the nearest common root folder) containing all files and folders (named as specified in the archive). |
Multiple files or folders without a common root folder |
A job folder (named as the archive after stripping the extension) containing all files and folders (named as specified in the archive). |
Uncompress allows only a single outgoing connection
Name |
The name of the flow element displayed in the canvas. |
Passwords |
A list of passwords for opening password-protected archives; each of the passwords in the list will be tried in turn. The script expression can be used to determine a password dynamically, for example based on the sender of the packed data. Note: The result of the script expression evaluation must be a
string containing one password or a list of passwords
separated by a newline character ('\n').
Example: var thePasswords = new Array(); thePasswords.push( "password" ); thePasswords.push( "password2" ); thePasswords.join( '\n' ); |
Remove redundant folders |
If set to Yes, for archives where the files or job folders are contained in deeply nested subfolder structures, removes all but the deepest subfolder level while uncompressing Example: A PDF file that is compressed as "Folder 1\Folder 2\Folder 3\Test.pdf" is uncompressed as "\Folder3\Test.pdf", if this option is enabled. |
