Troubleshooting Action Lists - How it works
The Action List Visualizer allows you to see what each Action in an Action List is doing as it processes. This means that each of the Actions is executed, one after the other, while the impact of each Action is shown in the document on the page that is currently open. A pointer moves from the top to the bottom, to show you where the focus is.
The Action List must be started explicitly. See Starting the Action List Visualizer.
There are two ways to go through an Action List:
You can combine both methods, for example check the first x Actions of the Action List step by step and then the last part in Run mode, or vice versa.
You can also make changes to the attributes of the Action List with the Action List Visualizer active, and immediately check the effect of your changes. See Changing the Action List during visualization.
Tips:
