Allows you to change the print state of a layer, which determines whether or not objects on the layer are printed. Thanks to this Action, you can avoid that invisible content on a layer is printed accidentally (or the other way around).
Select layers <!-- Select layers --> Change layer print state <!-- with the option Print State must be: Prints when visible -->
