Creating and editing an Action List
Why edit an Action List
Most of the time, you will not be able to use the pre-defined Action Lists without adapting them to your needs. For example, you probably don't want to add an Enfocus background to your PDFs (using the "Add Enfocus Background" Action List), but your own company background. The easiest way to do so, is by editing the existing "Add Enfocus Background" Action List and replacing the Enfocus background image with your own background image.
Why create a new Action List
Although PitStop Pro provides a lot of default Action Lists, there are so many things you can do with a PDF, that you'll probably need other combinations and sequences of tasks than the ones that are predefined.
Ways to create Action Lists
You can create an Action List in different ways:
The Action List Editor
Action Lists can be created and edited via the Action List Editor. You can open this dialog in different ways:
  • To open a new Action List, in the Action List dialog, click > New > New .
  • To open an existing Action List, just double-click it in the Action List dialog.
